Showing results forĀ
Search instead forĀ
Did you mean:Ā
Nexus 5k Throwing Duplex Mismatch error even though Duplex/speed is correct
Hello Guys
We Are facing an issue with Duplex Match. error in nexus 5k
Our Nexus 5k Switch continously throwing Duplex mismtach error on Logs.
2013 Nov  9 07:53:24 FRMA_BK2_CSN5K_02 %CDP-4-DUPLEX_MISMATCH: Duplex mismatch discovered on Ethernet1/11, with LAGInterface0/3/1
2013 Nov  9 07:54:24 FRMA_BK2_CSN5K_02 last message repeated 8 times
2013 Nov  9 07:56:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 07:58:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:00:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:02:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:04:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:06:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:08:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:10:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:12:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:14:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:16:24 FRMA_BK2_CSN5K_02 last message repeated 16 times
2013 Nov  9 08:18:22 FRMA_BK2_CSN5K_02 last message repeated 15 times
The interface is connected to Cisco Wireless lan controller(5508) using port-channel. Other interface in Port channel is not facing an Issue.
This interface is hardcoded with Speed 1000. Same config on WLC also Speed 1000. No ipunt errors observed in the interfaces
But in Switch cdp this interface is showing as Half duplex and flooding the 5k with logs
Please find the Interface configs & CDP outputs,
interface port-channel124
  description Controller Wireless 5508
  switchport mode trunk
  spanning-tree bpduguard enable
  speed 1000
  storm-control broadcast level 80.00
  storm-control multicast level 80.00
  vpc 124
interface Eth 1/10 & 1/11 is binded in port channel 124.
Eth 1/10 --> dont have any Logs and showing full duplex in CDP.
Eth 1/11 --> Having Logs  for duplex mismtach and  showing half duplex
interface Ethernet1/10
  description Controller Wireless 5508 - Port 1
  speed 1000
  channel-group 124
interface Ethernet1/11
  description Controller Wireless 5508 - Port 2
  speed 1000
  channel-group 124
FRMA_BK2_CSN5K_02# sh int eth 1/10
Ethernet1/10 is up
  Hardware: 1000/10000 Ethernet, address: 547f.ee33.d031 (bia 547f.ee33.d031)
  Description: Controller Wireless 5508 - Port 1 - 10.80.82.240
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 1000 Mb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 16week(s) 6day(s)
  Last clearing of "show interface" counters 35w2d
  30 seconds input rate 6194968 bits/sec, 1211 packets/sec
  30 seconds output rate 4498096 bits/sec, 1189 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 4.81 Mbps, 875 pps; output rate 3.60 Mbps, 863 pps
  RX
    2055924941 unicast packets  547924 multicast packets  1043625 broadcast pack
ets
    2057516490 input packets  1047388804413 bytes
    82164348 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    2407546704 unicast packets  558419255 multicast packets  2765961466 broadcas
t packets
    5731927425 output packets  1625683967743 bytes
    342983729 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  2 interface resets
FRMA_BK2_CSN5K_02# sh int eth 1/11
Ethernet1/11 is up
  Hardware: 1000/10000 Ethernet, address: 547f.ee33.d032 (bia 547f.ee33.d032)
  Description: Controller Wireless 5508 - Port 2 - 10.80.82.240
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  30 seconds input rate 2059992 bits/sec, 712 packets/sec
  30 seconds output rate 3605536 bits/sec, 680 packets/sec
    input rate 1.44 Mbps, 485 pps; output rate 2.73 Mbps, 546 pps
  RX
    1742986162 unicast packets  712358 multicast packets  1587374 broadcast pack
ets
    1745285894 input packets  813329974630 bytes
    107173365 jumbo packets  0 storm suppression bytes
    0 Rx pause
  TX
    1347189732 unicast packets  337957710 multicast packets  2429529386 broadcas
t packets
    4114676828 output packets  1302894776466 bytes
    308726768 jumbo packets
    0 Tx pause
  3 interface resets
FRMA_BK2_CSN5K_02# sh cdp neighbors interface ethernet 1/11 detail
Device ID:FRMA_BK2_WLCCS5508_01_100
System Name:
Interface address(es):
    IPv4 Address: 10.80.82.240
Platform: AIR-CT5508-K9, Capabilities: Host
Interface: Ethernet1/11, Port ID (outgoing port): LAGInterface0/3/1
Holdtime: 136 sec
Version:
Manufacturer's Name: Cisco Systems Inc.  Product Name: Cisco Controller  Product
Version: 7.0.240.0  RTOS Version: Erro  Bootloader Version: 1.0.1  Build Type:
DATA + WPS + LDPE
Advertisement Version: 2
Duplex: half
System Name:
Interface: Ethernet1/11, Port ID (outgoing port): GigabitEthernet0/0/2
Holdtime: 136 sec
Version:
DATA + WPS + LDPE
Duplex: full
FRMA_BK2_CSN5K_02# sh cdp neighbors interface ethernet 1/10 detail
System Name:
Interface: Ethernet1/10, Port ID (outgoing port): GigabitEthernet0/0/1
Holdtime: 138 sec
Version:
DATA + WPS + LDPE
Duplex: full
From WLC Controller end
(Cisco Controller) >show port summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE    SFPType
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
2  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
What might be the issue here?
Thanks for your suggstion
6 Replies 6
glen.grant
  The lan controller shows this , which shows "auto" for mode.  Change the switch end to auto instead of a hardcoded speed of 1000 this could be causing your mismatch .  Switch end does not need ot be hardcoded.
Hi Grant,
Thanks for your sugggestions.But however  we Have 6 Controllers, all are having the same setup as this one.
Only difference i seen for this switch is for the th port 1/11 it is showling 2 CDP info,  one for management interface of WLC and other for Logical interface of WLC, which seems not correct.
Ths CDP info connecting to Logical interface is showing half duplex and cdp info connecting to Physical interface of wlc is showing full duplex.
FRMA_BK2_CSN5K_02# sh cdp neighbors int eth 1/11 detail
System Name:
Holdtime: 125 sec
Version:
DATA + WPS + LDPE
Duplex: half
System Name:
Holdtime: 125 sec
Version:
DATA + WPS + LDPE
Duplex: full
Guys,
Any inputs here????
I'm having the same issue here - same alert, same CDP info. did you ever get a resolution?
Yes. we managed to resolve it.
Disabling the CDP v2 advertisement in the interface. Stops the logs.
A duplex mismatch is a situation where the switch  operates at full duplex and the connected device operates at half duplex  or vice versa. The results of a duplex mismatch are extremely slow  performance, intermittent connectivity, and loss of connection. Other  possible causes of data link errors at full duplex are bad cables,  faulty switch ports, or client software or hardware issues.
Resolution : Since for 5500s WLC , data rate is fixed 1k full duplex, please check the switch side data rate , make sure it is set to 1000 Mbps Full Duplex.
