Showing results forĀ
Search instead forĀ
Did you mean:Ā
Nexus 6000 DHCP configuration
incognito
Hello, friends!
Could you help me to configure DHCP on nexus? As I understand on nexus 6000 we can not configure DHCP pool/DHCP server (like on catalyst switches) and can configure only dhcp relay? Is it right?
If yes then I already installed DHCP server on Windows 2012 and created several DHCP scopes. What else I should do?
What is the difference between DHCP smart relay and DHCP relay?
Under which interface I should apply ip dhcp relay address x.x.x.x? Any explanation would be helpful
Config file of nexus is attached.
7 Replies 7
Hello
 wrote:
Hello, friends!
@incognito
Smart-relay is used when your have secondary ip addressing on your l3 interfaces and you wish to utilize both the primary and secondary ip addresses to obtain dhcp allocation for your clients.
Without this feature only your primary ip address is used in dhcp request to obtain an ip lease from the dhcp server and if it cannot retrieve any leases say because that scope is exhausted then its possible your clients wont obtain ip address allocation however with smart-relay this initiates the usage of the secondary ip address to request dhcp thus you can have some sort of resiliency for dhcp
DHCP-relay enable clients to request and receive dynamic ip address from a dhcp server that is located off its own subnet.
Under the L3 svi interfaces of each subnet you wish to receive dynamic ip address allocation and on NXOS the command would be:
int vlan xxx
ip dhcp relay address xxxxx
Kind Regards
Paul
Thanks, Paul!
i have the last question. Could you give an answer?
As I understand on nexus 6000 we can not configure DHCP pool/DHCP server (like on catalyst switches) and can configure only dhcp relay? I mean on nexus we cannot configure DHCP server? Do we must install separate DHCP Server on Windows server for example??Is it right?
Hello
Not necessarily dhcp server services could run on other high end switches or routers but i would say it much more applicable to use a designated server that is designed to service dhcp especially how closely dhcp/dns and active directory are today integrated it makes much more sense to run it on a server and leave the switch/routers to perform services what they are especially designed to do with the less burden of supporting dhcp.
Kind Regards
Paul
thanks Paul for the explanations
I understand you, but I want to be totally confident that on nexus 6000 we can not configure DHCP server on it. I mean that there is no any commands to configure DHCP Server, like this:
ip dhcp pool TEST
network x.x.x.x 255.255.255.0
default-router x.x.x.y
domain-name test.com
ip dhcp excluded-address x.x.x.x  x.x.x.y
Is it right?
Thats right not supported on any NX switch currently , there IOS commands , not available in NX software
See link below:
This applies to all Cisco Nexus series switches.
https://www.cisco.com/c/en/us/support/docs/switches/nexus-7000-10-slot-switch/113010-nexus-7k-faq-00.html#qa25
thanks for the answer.
but in this FAQ given information only for nexus 7000 series
as i understand for nexus 6000 it is the same as for 7000 ?
