Nexus 6004 NX OS Upgrade Path
jgorman1977
I’m planning to upgrade to 7.3(6)N1(1) from 5.1(3)N2(1c). Can I use the following path: 5.1(3)N2(1c)>7.1(4)N1(1)>7.3(6)N1(1)
Thanks in advance
Reza Sharifi
If you want to upgrade from a release on Cisco NX-OS release 7.0 train or earlier, you must first upgrade to Cisco NX-OS release 7.0(4)N1(1) and then to 7.1(4)N1(1).
So, 5.1(3)N2(1c)>7.0(4)N1(1)>7.1(4)N1(1)>7.3(6)N1(1)
Be sure to issue "show install all impact" command to identify the upgrade impact.
Also, use install all command during upgrades.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus6000/sw/upgrade/714_N1_1/n6000_upgrade_downgrade_714_n1_1.html#27676
marce1000
 - Study release notes from designated version in detail. It should contain this or related info's
    M.
balaji.bandi
nexus 5.1 is too old.
i believe you need to couple of upgrade and with small downtime to reload the switch.
i would personally do below :
5.1 -- 5.2 -- 7.0 - 7.1 -current your desired version.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus6000/sw/upgrade/735_N1_1/n6000_upgrade_downgrade_735_n1_1.html
Note : make sure you understand the upgrade path and caveats before the upgrade. always take backup config out of the box. when you do each upgrade,
BB
Reza Sharifi
