Nexus 6K: Port-Channel Load-Balance
kangyuxin
Hi all,
I configured "port-channel load-balance ethernet source-dest-mac" on Nexus 6001. But when I use "show run all | in load-balance", it displays module 1 and module 2 are still using source-dest-ip for port-channel load-balance. And for command "show port-channel load-balance" and "show port-channel load-balance forwarding-path interface", it still shows switch using MAC for hash algorithm. The NXOS is 6.0(2)N1(2a).
Does anybody know:
-  What is the function of "port-channel load-balance ethernet source-dest-ip module" and in which situation this command will be effective?
-  It shows "port-channel load-balance ethernet source-dest-ip module" command for both module 1 and 2. Module 1 is N6K Supervisor and module 2 is 4xQSFP Ethernet Module. Is it possible to set different load-balance algorithm  to these 2 modules?
# show run all | in load-balance
port-channel load-balance ethernet source-dest-ip module 1
port-channel load-balance ethernet source-dest-ip module 2
# show port-channel load-balance
Port Channel Load-Balancing Configuration:
System: source-dest-mac
Port Channel Load-Balancing Addresses Used Per-Protocol:
Non-IP: source-dest-mac
IP: source-dest-mac
# show port-channel load-balance forwarding-path interface port-channel 30 vlan 150 src-ip 172.25.228.6 dst-ip 172.25.226.97
Missing params will be substituted by 0's.
Load-balance Algorithm on switch: source-dest-mac
crc_hash: 977 Polynomial: CRC10b        Outgoing port id  Ethernet1/2
Param(s) used to calculate load-balance:
        seed: 0x701
        dst-mac:  0000.0000.0000
        src-mac:  0000.0000.0000
# show module
Mod Ports Module-Type                         Model                  Status
1   48    Norcal 64 Supervisor                N6K-C6001-64P-SUP      active *
2   10    Nexus 4xQSFP Ethernet Module        N6K-C6001-M4Q          ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    6.0(2)N2(3)     1.0     --
2    6.0(2)N2(3)     1.0     --
0 Replies 0
