NEXUS 7000 linecard reload
dguigo
Hello All,
We encountered a line card reload during connection tests.
I'm trying to understand what happened.
The technician on side just connected a laptop to a Ethernet port and the line card reloaded.
If I'm not misunderstanding I remenber that if you push simultaneoulsy the buttons located at the bottom left and right of the linecard (picture in file attached) the line card can reload. Is it correct ?. What is the benefits of these buttons ?.
Thanks you for your feedbacks,
David GUIGO
Matthew Blanshard
Hello David,
Those buttons lock the ejector levers into place.  You can check the following to see the reason for the line card reload:
show logging onboard module internal reset-reason
That will tell you if it was because of the ejector levers or something else.
-Matt
Hello Matthew,
Thank you for your feedback,
For the reset reason I have the following outputs :
Reset Reason for this card:
        Image Version : 4.2(4)
        Reset Reason (LCM): Unknown reason (44) at time Thu Dec 23 11:34:46 2010
        Reset Reason (SW): Unknown (0)
        Reset Reason (HW): Watchdog Timeout (2) at time Thu Dec 23 11:34:46 2010
        Last log in OBFL was written at time Mon Jan  3 10:51:03 2011
sh system reset-reason module 5
*************** module reset reason (5) *************
Time stamp   : At 179186 usecs after Thu Dec 23 11:33:53 2010
Service name : Registry
Reset reason : Module removed
Serial number: JAF1352BDDR
Error code   : NA
Do you think it's due to board buttons unlock ?.
Thanks and regards,
David.
Joris Deprouw
Hello David,
It is indeed due to the buttons that your card went offline.
When you push both buttons the card is disabled, ready to be removed.
You can check the status of the ejectors by doing "sh module x"
Ejector Status:
Left ejector CLOSE, Right ejector CLOSE, Module HW does support ejector based shutdown.
Ejector Status:
If you don't want the card to go offline when you push both ejectors, apply the command "no hardware ejector enable".
Best Regards,
Joris
