Nexus 7000 vPC suspended VLAN problem
Nicholas Poole
I am trying to connect a Cat3560G switch to an N7K pair via a vPC.  The VLANs I wish to trunk are being suspended, I am getting the following error messages:
2010 Jun 22 17:03:36 N7K-Core1 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 2,301 on Interface port-channel2 are being suspended. (Reason: Vlan is not allowed on Peer-link)
The VLANs do exist , but a STP instance isnt created for it (I am using RPVST);
N7K-Core1# sh vlan id 2
VLAN Name                             Status    Ports
2    VLAN0002                         active    Po2, Po75
N7K-Core1# sh spanning-tree vlan 2
ERROR: Spanning tree instance(s) for vlan does not exist.
Port       Vlans Err-disabled on Trunk
Eth1/9     none
Eth1/10    none
Eth1/17    2,301
Eth1/18    2,301
Eth1/25    2,301
Eth1/26    2,301
Eth2/2     none
Eth10/1    none
Eth10/2    2,301
Po2        2,301
Po75       2,301
Po99       none
The VLANs are allowed on the trunk (it by default allows all)
interface port-channel1
  description * vPC Peer-Link *
  vpc peer-link
  spanning-tree port type network
I have turned off bridge assurance as a test but no no avail.
Any ideas?
17 Replies 17
scneima01
HA! 6 years ago. I'll post my feedback anyway since my solution doesn't seem to be here and I keep running into this problem.
I did...
vlan blah
shut
!then
vlan blah
no shut
Badabing! Looks like vpc or something needed a little refresh and that was enough to get the switch to check again.
sanders.ryan
I ran into same exact problem...  Everything on the interface needs to match exactly to the other interfaces. I was missing the below from the edge switch side.
interface TenGigabitThernet1/0/1
 description vpc 1015
 switchport trunk native vlan xx
 switchport trunk allowed vlan x,x,x,x
 switchport mode trunk
 switchport nonegotiate
 spanning-tree link-type point-to-point
 channel-group 1 mode active
interface TenGigabitThernet1/0/2
 ip dhcp snooping trust  <<<<<<< This is what I was missing on the te1/0/1 interface which caused it
                                                              to go into "suspended" Once I added it came right up.
patricekoushesh
 I know the original post was for years ago.
Just to share. I had the same issue today. The mistake was that I did not define the desired VLAN on both vPC peers and got the same errors. So do not forget to define the VLAN on both vPC switches.
I wish I helped.
Patris
