Nexus 7000 WCCP with bluecoat ProxySG
Freemen
Scenario
Issue happen when firewall failover from primary to secondary then back to primary, HTTP and HTTPS traffic seam like not going out, error 503 gateway timeout was observed
  1. Swing fw from primary to secondary – OK
  2. Swing fw from secondary back to primary – traffic not going out. (WCCP or explicit)
  3. Notice is HTTP and HTTPS traffic which is intercepted WCCP.
  4. ICMP and DNS was able to reach out.
  5. Swing from primary back to secondary – OK
Weird is primary before swing is working fine, then secondary is also working fine.. why swing back to primary got issue.
My question is will the Portchannel 4003 inbetween N7K will cause double redirection? Then cause L3 loop?
Zhan Hua
Reza Sharifi
Can you try it with a sinle link intead of a Portchannel and see if you have the same results?
yes this is what we plan next .. i see if this solve this
You could do this by configuring two WCCP service groups as described in the previous examples. Or you could use the following commands to configure one service group for both types of traffic. The example also caches HTTP sessions on port 8080.
Enter the following command to add a service group to a WCCP server that caches HTTP sessions on ports 80 and 8080 and HTTPS sessions on port 443. Both of these protocols use protocol number 6. The IP address of the server is 10.31.101.100 and the WCCP clients are on the 10.31.101.0 subnet. The service ID of this service group is 90.
config system wccp
edit 90
set router-id 10.31.101.100
set server-list 10.31.101.0 255.255.255.0
set ports 443 80 8080
set protocol 6
end
Enter the following commands to configure a FortiGate unit to operate as a WCCP client and add a service group that configures client to cache HTTP sessions on port 80 and 8080 and HTTPS sessions on port 443. The IP address of the server is 10.31.101.100 and IP address of this WCCP clients is 10.31.101.1 subnet. The service ID of this service group must be 90 to match the service ID added to the server.
config system settings
set wccp-cache-engine enable
end
config system wccp
edit 90
set cache-id 10.31.101.1
set router-list 10.31.101.100
set protocol 6
end
