Nexus 7010 Fex Port-Channel
UniWAQ
Hallo All ,
we are using Nexus 7010 (having 4Port group) with the following inventory and three fex are attached with ProdcutionVDC by using 3 port-channel(4xPorts) with each module( 1/1-4, 2/1-4, 3/1-4) respectively.
Could we configure these port-channel by using 2  ports from each module (like 1/1-2 or  2/1-2 or  3/1-2) for redundancy purposes for each fex.
Secondly could we also configure access port-channels by taking ports from different modules for redundancy purposes.
Thanks in advance for feedback.
admin# show module
Mod  Ports  Module-Type                         Model              Status
1    48     1/10 Gbps Ethernet Module           N7K-F248XP-25E     ok
2    48     1/10 Gbps Ethernet Module           N7K-F248XP-25E     ok
3    48     1/10 Gbps Ethernet Module           N7K-F248XP-25E     ok
5    0        Supervisor Module-2                       N7K-SUP2E               ha-standby
6    0        Supervisor Module-2                       N7K-SUP2E              active *
 Mod  Sw              Hw
1    6.2(20)         1.0
2    6.2(20)         1.0
3    6.2(20)         1.0
5    6.2(20)         1.0
6    6.2(20)         1.0
show fex
FEX FEX FEX FEX
Number Description State Model Serial
102 FEX0102 Online N2K-C2232TM-E-10GE SSI1713021JY
104 FEX0104 Online N2K-C2232TM-E-10GE SSI171120B8H
105 FEX0105 Online N2K-C2232PP-10GE SSI1606031M
balaji.bandi
Yes that is way moving forward for redundancy purpose, either you can use different ASIC or different Line cards.
"Secondly could we also configure access port-channels by taking ports from different modules for redundancy purposes.  "
you mean to say FEX ? if not explain more.
BB
Thanks balaji.
How could we use with asic , you mean to say port-group or what , please guide me .
Secondly by using Fex ports could we use like these two interfaces for one port-channel attached with Server.
interface eth102/1/44 and  interface eth104/1/44
Here is the details about ASIC.
A switch is a layer 2 device that makes a decision based on the layer 2 frame destination MAC address. The more ports you add to a switch the more processing a switch is doing. Just a few ports can be handled by software written to run on an off-the-shelf CPU. As the number of switch ports increase, the general purpose CPU using software solution can't keep up. The ASIC is basically a CPU that is not a general purpose CPU but is a CPU for making switching decisions very quickly. It can't be used for much else. This is similar to a high-end graphics card that has a special CPU for graphics processing that wouldn't be good for general applications. Hence the name, Application Specific Integrated Circuit.
different ASIC can be used generally in case where you do not have redundant line cards to use to hardware fail case.
yes this is possible to use with Server.( configure server side also bundle).
BB
