04-14-2016 01:41 AM - edited 03-08-2019 05:21 AM
I have a N7K-M132XP-12L card in my chassis. From the notes it states it is a 10G card and only accepts 10G SFPs which is fine. But could I plug in a router link where the other end is 1G. Will this auto-negotiate down to 1G as that is the max the other end is capable of.
Or could I configure the port as an access port and configure a L3 vlan interface for it as a workaround?
Solved! Go to Solution.
04-14-2016 07:56 AM
Looks like its supports L2 and L3 i dont use these particular modules though but the data sheet says there fully capable for both
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/data_sheet_c78-720322.html
One thing i rememebr reading on these if M2 is in place in same VDC that may do the L3 routing
Table 2. Features and Benefits
Feature |
Benefit |
Support for 1 and 10 Gigabit Ethernet |
Each port can be used at 1 or 10 Gigabit Ethernet speed, allowing IT departments to migrate to 10 Gigabit Ethernet based on the unique requirements of their networks. |
Comprehensive Layer 2 and Layer 3 capabilities |
The comprehensive set of Layer 2 and Layer 3 functions makes this module excellent for data center networks. |
04-14-2016 01:58 AM
Hi Mokhalil
see this link
https://supportforums.cisco.com/discussion/11160071/support-1g-and-10g-n7k
04-14-2016 02:29 AM
Thanks Mark
I will also have a F2E in the same VDC. Would it be possible to configure an access port instead and have a L3 vlan interface
04-14-2016 07:56 AM
Feature |
Benefit |
