Nexus 7K input discards
Sarg .
Level 3
Level 3
Hello Team,
I seeing a number of discards on my Nexus 7K . Does anyone know how I can find out the packets that  are being discarded?
Please see the output below.
Ethernet3/48 is up
admin state is up, Dedicated Interface
  Belongs to Po1
  Hardware: 1000/10000 Ethernet, address:
  Description: Link to Telecity
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  reliability 255/255, txload 1/255, rxload 2/255
  Encapsulation ARPA, medium is broadcast
  Port mode is trunk
  full-duplex, 1000 Mb/s, media type is 1G
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned on
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
  Last link flapped 10week(s) 6day(s)
  5 interface resets
  30 seconds input rate 10881600 bits/sec, 2477 packets/sec
  30 seconds output rate 2799184 bits/sec, 1433 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 19.29 Mbps, 3.28 Kpps; output rate 4.57 Mbps, 1.74 Kpps
  RX
    60230024284 unicast packets  76060691 multicast packets  44682833 broadcast packets
    60350739048 input packets  66908411765118 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  332770 input discard
    0 Rx pause
  TX
    66422484197 unicast packets  64002660 multicast packets  21560447 broadcast packets
    66508013619 output packets  65774916044117 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  288477 output discard
    0 Tx pause
Akash Agrawal
Please check output of command " show hardware internal interface indiscard-stats front-port x "
Support for Granular Input Packet Discards Information
Beginning with Cisco NX-OS Release 5.0(3)U2(1), you can get a more detailed information on what specific condition led to an input discard on a given interface. Use the show hardware internal interface indiscard-stats front-port x command to determine the condition that could be potentially responsible for the input discards that are seen on port eth1/x. The switch output shows the discards for IPv4, STP, input policy, ACL specific discard, generic receive drop, and VLAN related discards.
Use the show hardware internal interface indiscard-stats front-port x command to determine the condition that could be potentially responsible for the input discards.
Here are the versions that I am using below but that command is not active on my 7K.
Software
  BIOS:      version 2.12.0
  kickstart: version 6.1(4a)
  system:    version 6.1(4a)
  BIOS compile time:       05/29/2013
  kickstart image file is: bootflash:///n7000-s2-kickstart.6.1.4a.bin
  kickstart compile time:  12/25/2020 12:00:00 [09/26/2013 07:22:01]
  system image file is:    bootflash:///n7000-s2-dk9.6.1.4a.bin
  system compile time:     7/8/2013 19:00:00 [09/26/2013 09:08:40]
Hardware
  cisco Nexus7000 C7004 (4 Slot) Chassis ("Supervisor module-2")
  Intel(R) Xeon(R) CPU         with 12225160 kB of memory.
Sorry, by mistake i provided command for Nexus 3000, while you have Nexus 7000. Can you please provide running config for interface where input discard is increasing and other side where it is connected. Sometimes it happens due to vlan mismatch, you are receiving traffic with vlan tagged which is not passed on received interface.
Below commands may also help you
show interface ethernet <x/x>
show interface ethernet <x/x> counters detailed all
show hardware internal errors module <slot No of the vpc member port>
show hardware internal statistics pktflow dropped
show interface ethernet <x/x> counters errors
-Akash
