Nexus 7k is going to be restarted if excute the claer mac address command
krishna chintada
Beginner
Beginner
Hi all,
We are facing some issues in Nexus 7K.when we excute the clear mac address command,it is going to be restarted.
Could you please suggest me what might be the reason ?
Thanks & Best regards,
Krishna Chintada
Reza Sharifi
It might be that you are encountering a bug in Nexus-OS.  Open a ticket with TAC to help you resolve the issue.
A clear mac should not reload a box.  That is a code issue.
cer43tcent
Beginner
Beginner
I have no experience with Nexus but wondered if you could set the device to reload in 10 like in IOS and then clear the MAC address table.  If it didn't restart after clearing the MAC table you could do reload cancel.  Although the bigger issue still remains its probably a bug.
