02-06-2021 12:10 AM
I am using Nexus7000 C7009 (9 Slot) Chassis in my environment with N7K-F248XP-25E installed on 3rd Slot.
Since a week I am facing a issue that, full slot stop working after some period of time and status on the card has RED Indication. When I jack out and jack in the card It works for sometime and again goes down, can anyone tell me what is the exact issue.
02-06-2021 01:22 AM
- Probably an upcoming hardware problem, check the logs on the nexus server when this happens, or use a syslog-server as log-collector.
M.
02-06-2021 01:32 AM
Can you post-show modules (sometimes you mixing with other modules may have an issue) - by saying most cases F2 cards should work.
Look at RED LED mean :
worth posting the logs while insertion to exit to understand what was the process and why it got an error.
02-06-2021 02:10 AM
02-06-2021 03:10 AM
the output does not give any clue other than the interface going up and down on slot3
we need logs when you inserted and removed.
02-06-2021 03:11 AM
- The card is probably developing a hardware problem, you may have it replaced.
M.
02-06-2021 05:15 AM
Sir,
Can I check by inserting the card in different slot...
02-06-2021 06:19 AM
You can try, either case we need to see more Logs ( when you insert the card capture the full logs)
along with show module information.
if this production network as suggested raise a TAC case for RMA.
02-06-2021 06:21 PM
I think no hard error
I think this is because the auto speed,
only config the Speed on this interface and see the result.
Hope this is the issue here.
