Nexus 7K Power Requirements
matthew.mcbride
Level 4
Level 4
I apologize if this is clearly documented somewhere but I was not able to find an answer. I have a couple Nexus 7ks with 6kW PSUs installed and 30a/208v whips under the cabinet. I know the 7.5kW PSUs require 30A circuits and thus ship with the NEMA 6L-30 cord option. What I can't determine is will the 6kW PSUs run on 30A AC circuits and if so will the same NEMA 6L-30 cord designed for the 7.5kW PSUs work on the 6kW PSUs?
-Matt
Giuseppe Larosa
Hello Matt,
6 KW power supplies have different AC inputs and use different cables
see
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/ps9512/Data_Sheet_C78-437761.html
6KW
International Electrotechnical Commission (IEC)  320-C19
7,5 KW
IEC 60309 for INT
NEMA L6-30 for US
there are also pictures showing clearly the AC inputs have different shapes
We have recently installed two
here is the sample of sh environment power
Power Supply:
Voltage: 50 Volts
Power                              Actual        Total
Supply    Model                    Output     Capacity    Status
                                 (Watts )     (Watts )
1        N7K-AC-6.0KW               512 W       6000 W     Ok
2        N7K-AC-6.0KW               469 W       6000 W     Ok
3        N7K-AC-6.0KW               579 W       6000 W     Ok
                                  Actual        Power
Module    Model                     Draw    Allocated    Status
                                 (Watts )     (Watts )
1        N7K-M132XP-12              N/A          750 W    Powered-Up
5        N7K-SUP1                   N/A          210 W    Powered-Up
6        N7K-SUP1                   N/A          210 W    Powered-Up
10       N7K-M132XP-12              N/A          750 W    Powered-Up
Xb1      N7K-C7010-FAB-1            N/A           60 W    Powered-Up
Xb2      N7K-C7010-FAB-1            N/A           60 W    Powered-Up
Xb3      N7K-C7010-FAB-1            N/A           60 W    Powered-Up
Xb4      N7K-C7010-FAB-1            N/A           60 W    Powered-Up
Xb5      N7K-C7010-FAB-1            N/A           60 W    Powered-Up
fan1     N7K-C7010-FAN-S            N/A          720 W    Powered-Up
fan2     N7K-C7010-FAN-S            N/A          720 W    Powered-Up
fan3     N7K-C7010-FAN-F            N/A          120 W    Powered-Up
fan4     N7K-C7010-FAN-F            N/A          120 W    Powered-Up
N/A - Per module power not available
Power Usage Summary:
Power Supply redundancy mode (configured)              PS-Redundant
Power Supply redundancy mode (operational)             PS-Redundant
Total Power Capacity (based on configured mode)              12000 W
Total Power of all Inputs (cumulative)                       18000 W
Total Power Output (actual draw)                              1560 W
Total Power Allocated (budget)                                3900 W
Total Power Available for additional modules                  8100 W
Hope to help
Giuseppe
Giuseppe Larosa
Hello Matt,
see
6KW
7,5 KW
IEC 60309 for INT
NEMA L6-30 for US
Power Supply:
Voltage: 50 Volts
Power                              Actual        Total
                                 (Watts )     (Watts )
                                  Actual        Power
                                 (Watts )     (Watts )
Hope to help
Giuseppe
Giuseppe,
Good point. And it does not appear Cisco makes a power cord for the 6kW PSU with the NEMA 6L-30 plug type on the far end. Thanks for your input.
-Matt
