Nexus 7k redistribute static into OSPF to block one static route
Steev112
Hi All,
i want to do redistribute static route into ospf on N7k, for example all want to advertise all static route except one route, i tried why access-list but unfortunately i can't block this route.
how can achieve it?
6 Replies 6
Seb Rupik
Hi there,
Can  you provide the OSPF and relevant ACL config so we can see what needs tweaking?
cheers,
Seb.
chrihussey
Are you using a route-map?
ip access-list STATIC_ROUTES
  10 deny ip 1.1.1.0/24 any
  20 permit ip any any
route-map STATIC permit 10
 match ip address STATIC_ROUTES
router ospf 100
  redistribute static route-map STATIC
Hello
Try a prefix-list instead:
NX-OS
ip prefix-list tst deny 1.1.1.0/24
ip prefix-list tst permit 0.0.0.0/0 le 32
route-map stan permit 10
match ip address prefix-list tst
feature ospf
int x/x
ip address x.x.x.x y.y.y.y
ip router ospf x area x
router ospf 1
router-id x.x.x.x.
redistribute static route-map stan
end
clear ip ospf  redistribution
Kind Regards
Paul
Hi Paul,
Thanks for your reply, i will try and update you.
Hi chrihussey,
i have tried this but didn't work.
10 permit ip 1.1.1.0/24 any
route-map STATIC deny 10
route-map STATIC permit 20
router ospf 100
