Nexus 9000 (93180YC-FX) netflow configuration
Amal Ahmadov
Hi there,
I have some questions regarding Netflow in Nexus 9000 series.
1. Can we mix in flow record Layer 3 and Layer 2 match clauses and apply it to Layer 3 or to Layer 2 interface? The idea is to see in Netflow collector both Layer 2 (MAC) and Layer 3 (IP) information using one flow record. For example,
flow record TEST-RECORD
match datalink mac source-address
match ipv4 source address
2.Can we apply Layer 3 flow monitor to VLAN? If yes, what is command for this? According to Cisco document, IP and IPv6 flow monitors can be applied to VLANs, SVIs, Layer 3 routed interfaces, or subinterfaces.
Thanks and have a nice day!
Best regards,
Amal
8 Replies 8
pman
Amal Ahmadov
Your answer shows that we can apply  Layer 3 flow monitor to VLAN. Yes, Cisco guide says so too. How can we apply Layer 3 flow monitor to VLAN? What is the command?
From Cisco document: Layer 2 switched flow monitors are applied only to Layer 2 interfaces. IP and IPv6 flow monitors can be applied to VLANs, SVIs, Layer 3 routed interfaces, or subinterfaces.
https://www.cisco.com/c/en/us/td/docs/dcn/nx-os/nexus9000/102x/configuration/system-management/cisco-nexus-9000-series-nx-os-system-management-configuration-guide-102x/m-configuring-netflow-10x.html
pman
Configuring Bridged NetFlow on a VLAN
You can apply a flow monitor to a VLAN in order to gather Layer 3 data over Layer 2 switched packets in a VLAN.
switch# configure terminal
switch(config)#
switch(config)# vlan configuration 30
switch(config-vlan-config)#
switch(config-vlan-config)# ip flow monitor testmonitor
another one:
Flexible Netflow configuration example:
Create the Flow Record:
flow record ipv4
match ipv4 tos
match ip protocol
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect counter bytes long
collect counter packets long
Create Flow Exporter:
flow exporter NetFlow-to-Orion
destination 10.10.10.10
source ethernet 2/1
transport udp 2055
version 9
template data timeout 60
Create Flow Monitor:
flow monitor NetFlow-Monitor
description Original Netflow captures
record ipv4
cache timeout inact 10
cache timeout act 60
Apply Flow Monitor to Interface:
vlan configuration 700
ip flow monitor NetFlow-Monitor input
https://support.solarwinds.com/SuccessCenter/s/article/Nexus-9k-Nexus-9000-Netflow-support?language=en_US
Amal Ahmadov
According to the guide we can apply Layer 3 Netflow to Layer 2 interface. Tried to apply to Layer 2 port-channel and got the following error.
Configuring Layer 3 NetFlow on Layer 2 Interfaces
You can define Layer 3 flow monitors on Layer 2 interfaces to capture Layer 3 flow information on Layer 2 interfaces.
My configuration:
flow record TEST-RECORD-L3
match ip protocol
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow monitor TEST-MONITOR
exporter TEST-EXPORTER
sw(config)# int port-channel 1
sw(config-if)# layer2-switched flow monitor TEST-MONITOR input
ERROR: Protocol for record and monitor do not match
Is there any Netflow method to get Layer 3 information from Layer 2 interface?
Thanks.
 The layer 2 flow record is different than the layer 3 flow record that way IoT may not be pulling anything.
hope below documents will help.
http://www.network-node.com/blog/2016/5/26/configuring-and-troubleshooting-netflow-part-2
https://unifiedguru.com/cisco-nx-osios-netflow-comparison/
https://overlaid.net/2014/07/09/configuring-netflow-on-nexus-nxos/
Jitendra
Amal Ahmadov
I think sflow is the way to go with gathering layer 2 and layer 3 information from layer 2 interface.
feature sflow
sflow collector-ip xxx.xxx.xxx.xxx vrf default source yyy.yyy.yyy.yyy
sflow agent-ip yyy.yyy.yyy.yyy
sflow collector-port 2055
sflow data-source interface port-channel 10
The most notable difference of SFlow vs NetFlow is that SFlow is network layer independent and has the ability to sample everything and to access traffic from OSI layer 2-7, while NetFlow is restricted to IP traffic only. (C)
Correct
Jitendra
