Nexus 9300 vPC setup issue
maniac79
I'm trying to setup two Nexus 9300 series switches for a vPC but keep running into an issue. When I run "ping 10.1.1.2 vrf heartbeat it works on both switches with the IP of the other switch. When I do a show vpc brief it says I'm down.
vPC domain id : 200
Peer status : peer link is down
vPC keep-alive status : Suspended (Destination IP not reachable)
Configuration consistency status : failed
Per-vlan consistency status : success
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason : Consistency Check Not Performed
vPC role : none established
Number of vPCs configured : 0
Peer Gateway : Enabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Disabled (due to peer configuration)
Auto-recovery status : Disabled
Delay-restore status : Timer is off.(timeout = 30s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
Virtual-peerlink mode : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po1 up -
Any suggestions?
Switch 1 config
version 9.3(10) Bios:version 07.64
hostname sw1
cfs eth distribute
feature interface-vlan
feature lacp
feature vpc
vlan 1,3005
vlan 3005
name VPC_Heartbeat
vrf context heartbeat
vrf context management
vpc domain 200
role priority 200
system-priority 150
peer-keepalive destination 10.1.1.2 source 10.1.1.1
peer-gateway
ip arp synchronize
interface Vlan1
no ip redirects
no ipv6 redirects
interface Vlan3005
description VPC heartbeat
no shutdown
vrf member heartbeat
no ip redirects
ip address 10.1.1.1/30
no ipv6 redirects
interface port-channel1
switchport
switchport mode trunk
switchport trunk allowed vlan 2-4094
spanning-tree port type network
vpc peer-link
interface Ethernet1/44
description VPC Heartbeat
switchport
switchport access vlan 3005
logging event port link-status
no shutdown
interface Ethernet1/47
switchport
channel-group 1 mode active
no shutdown
interface Ethernet1/48
switchport
no shutdown
interface mgmt0
vrf member management
ip address 10.224.102.2/30
line console
line vty
boot nxos bootflash:/nxos.9.3.10.bin
Sw 2 config
version 9.3(10) Bios:version 07.65
vdc switch id 1
cfs eth distribute
feature lacp
feature vpc
vlan 1,3005
vlan 3005
name VPC_Heartbeat
vpc domain 200
role priority 250
system-priority 150
peer-keepalive destination 10.1.1.1 source 10.1.1.2
peer-gateway
interface Vlan1
no ip redirects
no ipv6 redirects
interface Vlan3005
no shutdown
no ip redirects
ip address 10.1.1.2/30
no ipv6 redirects
switchport
vpc peer-link
switchport
no shutdown
switchport
no shutdown
switchport
no shutdown
interface mgmt0
line console
line vty
Thank you for your assistance
peer-keepalive destination 10.1.1.2 source 10.1.1.1 vrf heartbeat <<- this need both side
MHM
MHM
balaji.bandi
read the guide lines of vpc keepalive and vpc peer-link
We recommend that you associate the vPC peer-keepalive link to a separate VRF mapped to a Layer 3 interface in each vPC peer device. If you do not configure a separate VRF, the system uses the management VRF and management ports by default. Do not use the vPC Peer-Link itself to send and receive vPC peer-keepalive messages.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_chapter_0111.html#...
example of vPC can be find below my Blog :
https://www.balajibandi.com/?p=618
BB
