Nexus 93108TC-FX3P and QSFP-100G-CU1M cables
kerstin-534
we have 2 Nexus 93108TC-FX3P with QSFP-100G-CU1M cables connected together, link does not come up, what could be the matter ? Software version 9.3.11
Can you set the speed and duplex under the interfaces and try again?
7 Replies 7
Reza Sharifi
According to the compatibility matrix, the cable should be supported as of NX-OS 9.3.5 and later.
Could it be a bad cable?
Can you make sure the ports are not admin down?
Does the switch recognize the cable?
https://tmgmatrix.cisco.com/?si=93108TC-FX3P
kerstin-534
yes, I have seen this in Matrix, should work
I have tried to disable fec too, no success
!Command: show running-config interface Ethernet1/54
!Running configuration last done at: Tue Jun 13 19:44:12 2023
!Time: Tue Jun 13 19:49:02 2023
version 9.3(11) Bios:version 05.47
switchport mode trunk
no shutdown
switch-003# sh int eth1/54 transceiver details
Ethernet1/54
transceiver is present
type is QSFP-100G-CR4
name is CISCO-LEONI
part number is L45593-D218-D10
revision is 01
serial number is LCC2622GRGG-A
nominal bitrate is 25500 MBit/sec
Link length supported for copper is 1 m
cisco id is 17
cisco extended id number is 16
cisco part number is 37-1666-01
cisco product id is QSFP-100G-CU1M
cisco version id is V01
DOM is not supported
I have tried 4 different cables, no success
no, speed/duplex/negotiation commands are not available if cable is inserted
kerstin-534
yes, we have SUCCESS ! you are right
speed commmand before pluging cable in, then the link comes up !
Glad it is all working for you now.
