Nexus 93180YC-FX3 QSFP+ FET breakout cable
dal
Level 3
Level 3
I have 2 93180YC-FX3 that I need to connect to my Catalyst 9500 switches.
I have this 40G breakout cable called QSFP+ FET that would have been nice to use for the purpose
But how do i enable this feature on the Nexus 93180?
I get a link in the Catalyst 9500, but no info. No CDP or no mac address either.
Will it even work as long as it is a FET cable?
dal
Level 3
Level 3
The command for enabling the breakout from 40G to 10G is:
interface breakout module 1 port 53 map 10g-4x (port 53 is Eth1/53)
I have link connection between the switch, but no traffic goes over the link.
So I'm guessing that answers the question that a FET transciver is not suited for links between other nodes than FEX'es
