12-16-2024 04:18 PM
Hi guys.
I have a Cisco switch, model c3850-48xs-s. Can I put a glc-lh-smd sfp in its 10 gigabit ports for my 1 gigabit fiber links and have the fiber optic link established?
Solved! Go to Solution.
12-16-2024 06:38 PM
The link will establish as long as you configure the port correctly and the far-end device matches the speed, sometimes you may need to manually set the interface speed to 1 Gbps on the switch, as some SFP+ ports don't auto-negotiate when using 1 Gbps modules
12-16-2024 05:22 PM
Yes, that will work.
12-16-2024 06:38 PM
