Nexus 9336 kernel error
we do get the following errors when trying to dir bootflash: Input/output error
shortly before that we did upgrade to
install all nxos bootflash:nxos.9.3.7.bin"
"install epld bootflash:n9000-epld.9.3.7.img module all
 show logging last 10
2021 Dec 24 09:29:23 hrnmegdc100-02 %KERN-3-SYSTEM_MSG: [2288057.729289] blk_update_request: I/O error, dev loop10, sector 0 - kernel
2021 Dec 24 09:30:03 hrnmegdc100-02 %KERN-3-SYSTEM_MSG: [2288097.327236] blk_update_request: I/O error, dev sda, sector 0 - kernel
did we done something wrong ?
Software
  BIOS: version 05.43
 NXOS: version 9.3(7)
  BIOS compile time:  12/22/2020
  NXOS image file is: bootflash:///nxos.9.3.7.bin
  NXOS compile time:  3/10/2021 3:00:00 [03/10/2021 14:12:12
when we try to get show tech we get this error first:
 show tech-support > bootflash:TechSupport.txt
Error: could not open temporary file /bootflash/TechSupport.txt (errno=30)---- show tech-support ----
Show tech brief will take  4-6 minutes to complete. Please Wait ...
but then we finally get the output on the screen;
Boris
7 Replies 7
balaji.bandi
Looks like some bug htting :  ( make sure you offload the config before you take any action) - is this vPC  or standalone switch ?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs79768?rfs=iqvred
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuo44829?rfs=iqvred
BB
this is vPC switch, do we need to replace it as its still in warranty ?
BR
Raise an TAC case they will advice you.
BB
we did reboot and issue looks resolved, but will monitor next few days;
thank you for your answers
yes some time reboot fix the issue, due to Long uptime may cause issue, glad all good. in case it appears again may be Time for TAC.
BB
340031390
Community Member
How did you solve it in the end?
I also have this problem!Four switches appear simultaneously 。
device is uptime more than 3 years.
NXOS: version 9.2(3)  Nexus9000 93180YC-EX
2023 Oct 23 19:15:42.405 N9K-2_DS-Backup %KERN-3-SYSTEM_MSG: [104489190.336526] blk_update_request: I/O error, dev loop9, sector 0 - kernel
we did reboot and issue got resolved, but monitor next few days;
