Nexus 9396 - unable to set enable secret
Anukalp S
Hi.. I have been running nexus 9396 switches in VPC, what I am seeing strange here is primary nexus switch has no option to set enable secret but this option is available on secondary nexus. I don't know what is problem here why I am not able to set enable secret on primary nexus.
This is working for Secondary nexus.
N9K-Pri(config)# ?
  aaa              Configure aaa functions
  acllog           Configure ACL logging
  as-format        Configure the router's Autonomous system number (ASN) notation
  banner           Configure banner message
  bloggerd         Blogger commands
  boot             Configure boot variables
  callhome         Enter the callhome configuration mode
  cdp              Configure CDP parameters
  cfs              CFS configuration commands
  class-map        Configure a class map
  cli              Configure CLI commands
  clock            Clock
  control-plane    Enter to control-plane sub-mode
  copp             Control-Plane Policing
  default          Rollback to default configuration
  diagnostic       Diagnostic commands
  email            Configure pipe email
  errdisable       Error disable
  event            Event Manager commands
  feature          Enable the feature
  feature-set      Enable feature-set
  hardware         Hardware Internal Information
  hardware         Hardware information
  hostname         Configure system's host name
  hsrp             HSRP interface configuration commands
  hw-module        Enable/Disable OBFL information
Software
  BIOS: version 07.17
  NXOS: version 6.1(2)I3(4a)
  BIOS compile time:  09/10/2014
  NXOS image file is: bootflash:///n9000-dk9.6.1.2.I3.4a.bin
  NXOS compile time:  5/10/2015 1:00:00 [05/10/2015 14:29:05]
Hardware
  cisco Nexus9000 C9396PX Chassis
  Intel(R) Core(TM) i3-3227U C with 16402540 kB of memory.
  Processor Board ID SAL1820SDLW
N9K-Sec(config)#  ?
  clock            Clock
  enable           Create secret for privilege escalation
Software
  BIOS: version 07.17
Hardware
  Processor Board ID SAL1820SMKV
Mark Malone
hi is the feature enabled , you have to turn everything on first in nx-os
(conft)feature privilege
enable secret should work then
