Nexus 9508 SVI interface packet loss and High Latency
CSCO12361421
Hi Expert
I have a problem on Nexus 9508. I have two nexus 9508. our campus are using this switch as a gateway. we create 10-12 SVI interface on it. Problem is when we ping our gateway we face high latency and some time packet loss. But when we try to ping internet and other ip which is not nexus ip it ping replay very smooth and latency is good. We also find some time CPU usages climb on 50-60% . Any body have any idea. Please help..
willwetherman
This is possibly due to control plane policing. I observed the same behaviour during a 9396PX installation whereby pings to the SVIs resulted in high latency during normal operation and high latency and packet loss when a vPC peer was unavailable, however, all traffic including pings that transited the 9ks was fine.
The Nexus 9k has a number of built-in policies with the default being ‘strict’ I believe.
show copp status
Last Config Operation: None
Last Config Operation Timestamp: None
Last Config Operation Status: None
Policy-map attached to the control-plane: copp-system-p-policy-strict
Please check the control-plane stats by issuing the below command. Do you see any drops under this class?
show policy-map interface control-plane class copp-system-p-class-monitoring
Reza Sharifi
Its maybe because CoPP is configured on Nexus platforms.   See link below:
https://supportforums.cisco.com/document/107031/packet-loss-when-pinging-fromto-nexus-7000
Thanks Reza..
willwetherman
show copp status
Thanks willwetherman.
Yes you r right. I create customize control panel  services policy. But i cant customize default copp-system-p-policy-strict. Thaks again..
