Nexus 9508 Using The CVR-QSFP-SFP10G
Robert Ho
Hi, we have a Nexus 9508 with a 36-Port 40GE module (N9K-X9636PQ).
The servers, with 10GE SFP+ optics, are too far to use the 5m passive breakout cable.
Does the 40GE modules support the QSA module(CVR-QSFP-SFP10G) so that we can connect a 10GE SFP+ optic into it?
We looked at the doc below and it does not mention the Nexus 9508.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_24900.html
Thank you!
8 Replies 8
Reza Sharifi
Not that this answer your specific question, but you can also use patch panels if you have the backbone cable infrastructure in place.
example:
40Gig MTP with 4 breakout 10Gig LC.  Plug the 40Gig in to the 9500 and the LCs into the patch panel and if you have backbone infrastructure cable between cabinets, on the other cabinet patch the 10Gig LC from the server in to the patch panel.
Hi Reza,
I looked at the data sheet and it appears that all the breakout cables has a 10GE SFP+ tranceiver at the end. It does not appear to have a breakout cable that somehow terminates to an LC connector so that we can plug into a patch panel or fiber coupler. Do you by chance have the link or part number of the breakout cable you are referring to? Thanks!
You need to configure the 40g port as an individual breakout using the cli command "interface breakout slot 4 port 1-3 map 10" first.
Then you can use single mode optic in the QSA
Here is an output from the transceiver
Eth4/1/1      ***                                            full    10G     10Gbase-LR
Eth4/1/2      --                 notconnec 1         full    10G     QSA
Eth4/1/3      --                 notconnec 1         full    10G     QSA
Eth4/1/4      --                 notconnec 1         full    10G     QSA
Eth4/2/1      ***                                            full    10G     10Gbase-LR
6004# show int eth4/1/1 transceiver de
Ethernet4/1/1
    transceiver is present
    type is 10Gbase-LR
    name is CISCO-FINISAR
    part number is FTLX1474D3BCL-CS
    revision is A
    serial number is FNS1733054F
    nominal bitrate is 10300 MBit/sec
    Link length supported for 9/125um fiber is 10 km
    cisco id is --
    cisco extended id number is 4
Further info as well
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/operations/interfaces/602_n1_1/N5K_Interfaces_Ops_Guide/n5k_qsfp-_portsoperations.html#wp998392
Also find the configurations which you will need to input:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/operations/interfaces/602_n1_1/N5K_Interfaces_Ops_Guide/n5k_qsfp-_portsoperations.html#wp1001206
Arnold
The QSA listed(CVR-QSFP-SFP10G) is not supported on this linecard (N9K-X9636PQ). As a second option, you can do dynamic breakout on the 9636PQ card starting in 7.0(3)I1(1). Having break out 1 port to 4x10 and use that for his 10G.
Cisco NX-OS Release 7.0(3)I1(1)
I hope this helps.
I have the same linecard (N9K-9636PQ) and I need to connect some uplinks in 10 Gig. I have the CVR-QSFP-SFP10G adaptors with an SFP+ (SFP-10G-SR) but I cannot get link up on this ports. Checking the config of the port I see that I am allowed to set the port speed in 10000 (10 gb) but if I check the port capabilities it only shows 40000 (40 g). Are this ports compatible with the adaptors + a 10 G SFP?
Thank you.
Did you resolve the problem? I also met this issue, my switch is Nexus 6004. The port is always "Link not connected" but the other side (switch 5548) port status is connected. And when I set the speed to 10000, it says "ERROR: Ethernet2/12: Configuration does not match the port capability". Does it need some special configuration for QSA? I googled a lot but with no luck.
Thanks.
hi Guys,
did you get it resolved, i am having exactly same issue with CVR-QSFP-SFP10G module. my platform is N5624Q and apparently adapter is supported, Nexus OS Version is better then the one mentioned.
thanks
Hi guys,
Actually I have the same problem. I want configure a trunk between two Nexus 3172tq.
I have two qsa 40g, with 2 SFP-10Gb-SR. Fiber optic SM.
running-config:
interface ethernet1/54/1
 switchport mode trunk
 switchport trunk native vlan 100
 switchport trunk allowed vlan 100-120
 speed 10000
 no shutdown
interface ethernet1/54/2
 no shutdown
interface ethernet1/54/3
 no shutdown
interface ethernet1/54/4
 no shutdown
and when I write the command show interface status:
port              status           vlan     du
eth1/54/1     notconnect   trunk   full    10G    10Gbase-LR
eth1/54/2     xcvrAbsen    trunk   auto  10G         --
eth1/54/3     xcvrAbsen    trunk   auto  10G         --
eth1/54/4     xcvrAbsen    trunk   auto  10G         --
