02-16-2024 08:33 AM
nxos.9.3.12.bin
Having a strange issue with our N9K's. There a re long pauses between any commands entered. Checked logs and saw:
2024 Feb 16 15:55:50 DC3-N9K-BGW01 %TACACS-4-TACACS_WARNING: Problem during name-lookup. Error:-3(temporary failure in name resolution)
2024 Feb 16 16:00:21 DC3-N9K-BGW01 %TACACS-4-TACACS_WARNING: Problem during name-lookup. Error:-3(temporary failure in name resolution) (message repeated 1 time)
2024 Feb 16 16:03:11 DC3-N9K-BGW01 %TACACS-4-TACACS_WARNING: Problem during name-lookup. Error:-3(temporary failure in name resolution) (message repeated 3 times)
There is no name lookup configured on this device and all entries are IP based so dependency on DNS. Could this be a bug?
02-16-2024 08:38 AM
02-16-2024 08:45 AM
is your connectivity to TACACS good ? using source interface, is this intermediate or same all the time ?
Look at the below thread :
02-16-2024 09:02 AM
There are 4 of these devices hitting the same ISE servers via IP name. No connectivity issues between between anything.
02-16-2024 10:17 AM
can you post same configuration and
show tacacs-server statistics
02-18-2024 11:56 PM
aaa group server tacacs+ ISE_TACACS+
server 10.3.241.38
server 10.4.241.38
server 10.3.245.36
server 10.4.241.39
use-vrf management
sh tacacs-server statistics 10.3.241.38
Server is not monitored
Authentication Statistics
failed transactions: 14
successful transactions: 302
requests sent: 302
requests timed out: 14
responses with no matching requests: 0
responses not processed: 0
responses containing errors: 0
Authorization Statistics
failed transactions: 39
successful transactions: 1904
requests sent: 1904
requests timed out: 39
Accounting Statistics
failed transactions: 391
successful transactions: 1771
requests sent: 1772
requests timed out: 390
DC3-N9K-LEF01# sh tacacs-server statistics 10.4.241.38
successful transactions: 0
requests sent: 0
failed transactions: 40
requests sent: 0
requests timed out: 40
failed transactions: 290
successful transactions: 101
requests sent: 101
requests timed out: 289
DC3-N9K-LEF01# sh tacacs-server statistics 10.3.245.36
successful transactions: 13
requests sent: 13
failed transactions: 0
successful transactions: 54
requests sent: 54
requests timed out: 0
failed transactions: 162
successful transactions: 128
requests sent: 128
requests timed out: 162
DC3-N9K-LEF01# sh tacacs-server statistics 10.4.241.39
requests sent: 0
requests sent: 0
requests sent: 0
02-20-2024 12:51 PM
you using use-vrf management is this correct interface to reach ISE ?
02-27-2024 01:02 AM
Yes, that's the correct vrf as all the others.
