NEXUS: ACL on vrf context management
GIULIO FAINI
I need to configure a out ACL in the vrf contect management.
How to do that? I miss it..
DS1-R101(config-vrf)# ?
  ip        Configure IP features
  ipv6      Configure IPv6 features
  no        Negate a command or set its defaults
  shutdown  Shutdown current VRF
  end       Go to exec mode
  exit      Exit from command interpreter
  pop       Pop mode from stack or restore from name
  push      Push current mode to stack or save it under name
  where     Shows the cli context you are in
DS1-R101(config-vrf)# ip ?
  auto-discard  Auto 0.0.0.0/0 discard route
  domain-list   Add additional domain names
  domain-name   Specify default domain name
  igmp          IGMP global configuration commands
  mroute        Configure multicast RPF static route
  name-server   Specify nameserver address
  route         Route information
thanks!
Giulio
0 Replies 0
