Showing results forĀ
Search instead forĀ
Did you mean:Ā
Nexus command for logging discriminator?
Warren Sullivan
Hi all,
I have a log message that i want to supress, from the buffer, console, monitor and from being sent to our syslog collector, this is the log;
2015 Nov 9 14:29:14.389 Core-MAX-EMP-9372PX-01 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on vsh.14149
2015 Nov 9 14:30:16.400 Core-MAX-EMP-9372PX-01 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on vsh.14195
2015 Nov 9 14:31:18.406 Core-MAX-EMP-9372PX-01 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on vsh.14266
2015 Nov 9 14:32:20.405 Core-MAX-EMP-9372PX-01 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on vsh.14340
In IOS i could do this via logging discriminator;
logging discriminator Supress-CAT severity drops 5 facility drops VSHD mnemonics drops VSHD_SYSLOG_CONFIG_I
logging console discriminator Supress-CAT
logging buffered discriminator Supress-CAT 1000000
logging monitor discriminator Supress-CAT
logging host 10.60.1.211 discriminator Supress-CAT
But this command isnt supported in NX-OS
Is there a suitable replacement that you guys have found?
Thanks in advance!
Warren
Arun Yadav
Hi Warren,
logging discriminator is not available in NX-OS, it is something IOS specific configuration.
In Nexus if you want to suppress certain logs than you need to modify the logging level for that particular process or protocol.
In Nexus , you will only get below option in logging :-
