Nexus FEX primary fabric
stephen.ehlas
It appears that I have a problem with vpc connections to a single fex and the fex not showing any primary fabric port information. All the documentation I have read tells me that when I issue this command:
switch# show fex 100 detail
I should see this:
Fabric port for control traffic: Eth1/29
Fabric interface state:
Po100 - Interface Up. State: Active
Eth1/29 - Interface Up. State: Active
Eth1/30 - Interface Up. State: Active
Fex Port      State      Fabric Port      Primary Fabric
Eth100/1/1      Up      Po100                Po100
Eth100/1/2      Up      Po100                Po100
Eth100/1/3      Up      Po100                Po100
etc etc etc
But when I issue the command, all i see is this:
  Fabric port for control traffic: Eth1/19
  FCoE Admin: false
  FCoE Oper: true
  FCoE FEX AA Configured: false
    Eth1/19 - Interface Up. State: Active
    Eth1/20 - Interface Down. State: Configured
  Eth100/1/1     Down           None
  Eth100/1/2     Down           Po100
  Eth100/1/3     Down           Po100
There are no Primary Fabric listed. - Does anyone have any ideas on why this is happening?
Reza Sharifi
Can you post your config?
What is the code that you are using the in the Nexus devices, and please post your "show run fex" configuration in order to verify the status of this.
Robert Rodriguez
stephen.ehlas
#sh run fex
!Command: show running-config fex
!Time: Wed Jul 31 08:16:14 2013
version 5.2(1)N1(2a)
feature fex
fex 100
  pinning max-links 1
  description "Storage-FEX-1"
  type N2232TM-E
fex 101
  pinning max-links 1
  description "FEX0101"
interface Ethernet100/1/2
  speed 10000
interface port-channel1
  switchport mode trunk
  speed 10000
interface port-channel7
  speed 1000
interface port-channel100
  switchport mode fex-fabric
  fex associate 100
interface Ethernet1/11
  description Link to test Core
  speed 1000
interface Ethernet1/17
  description Peer Link to Core 2
interface Ethernet1/18
interface Ethernet1/19
  fex associate 100
interface Ethernet1/20
  fex associate 100
Hi Steve,
Your configuration is correct one and your FEX is showing up.
The output that is the documentation is from code 4.2 where it was showing the "Primary Fabric" option, in your code that doesn't show up anymore in the new codes.
You shouldn't concern about this situation.
