Nexus - HSRP and vPC, connectivity problem.
zykobot
Hopefully someone has come across this problem before...
The testing topology looks like this:
10.250.2.50 (VLAN 2502) -----> Nexus 2K -----> Nexus 5KA (SVI 2501, 2502) --------> Nexus 2K ------> 10.250.1.50 (VLAN 2501)
LAPTOP A                                           ------> Nexus 5KB (SVI 2501, 2502) ------->                              LAPTOP B
If I shutdown the interface vlan 2501 on Nexus 5K A or reboot Nexus 5K B... no problem, connectivity continues.
However, if I shut down interface vlan 2501 on Nexus 5K B, connectivity stops. Both laptops can still hit their gateways but connectivity between the two ceases... any ideas?
HSRP configuration looks like this..
Nexus 5K 1
interface Vlan2501
  no shutdown
  no ip redirects
  ip address 10.250.1.2/24
  hsrp version 2
  hsrp 2501
    preempt delay minimum 150 reload 300
    priority 150
    timers  1  3
    ip 10.250.1.1
Nexus 5K 2
interface Vlan2501
  no shutdown
  no ip redirects
  ip address 10.250.1.3/24
  hsrp version 2
  hsrp 2501
    preempt delay reload 300
    priority 90
    timers  1  3
    ip 10.250.1.1
vPC is configured like this..
vpc domain 1
  peer-switch
  role priority 2000
  system-priority 4000
  peer-keepalive destination 192.168.10.2 source 192.168.10.1 vrf VPC-KEEPALIVE-VRF
  delay restore 150
  peer-gateway
  auto-recovery reload-delay 300
  ip arp synchronize
zykobot
I adjusted the 'preempt' line to match on both sides.. made no difference.
To add to this.. I put both machines in the same VLAN 2501..
They can ping each other, they can both ping 10.250.1.1 (and SSH to)
However, Laptop B can't see 10.250.1.3 (I shut down 10.250.1.2) but Laptop A can.
