Nexus inband management with SVI
acontes
i have:
two nexus 5596 connected each other
the mgmt0 is NOT in use
SVI for keepalives with IP address and /30 netmask
vpc-keepalives running over fiber in e1/1. this works well
uplinks to datacenter distribution switch (Cat 6500 VSS) over fiber on port-channel 1 (e1/2 and e1/10), also carrying the management VLAN (vlan 14).
SVI with an IP address for management purposes
I can't get this to work. i can ping my whole network from the nexus, but not the nexus from my network. also pinging inside the mgmt vlan is not possible.
any ideas on that?
show vpc looks nice, show interface trunk looks nice,
7 Replies 7
Steve Fuller
Level 9
Level 9
Are you using the VRF in any way on this switch? Can you post a show run and show ip route output?
I do not use the management VRF in any other way.
Here is the relevant part of the sh running:
vrf context management
spanning-tree loopguard default
udld aggressive
port-channel load-balance ethernet source-dest-port
vpc domain 5
  role priority 1000
  system-priority 4000
  peer-keepalive destination 10.233.40.14 source 10.233.40.13 vrf default precedence 7
  peer-config-check-bypass
  auto-recovery
interface Vlan1
interface Vlan14
  no shutdown
  ip address 10.232.10.62/24
interface Vlan26
  no shutdown
  ip address 10.233.40.13/30
interface port-channel1
  description Uplink to VSS
  switchport mode trunk
  switchport trunk native vlan 236
  switchport trunk allowed vlan 14,236
  spanning-tree port type network
  speed 10000
  storm-control broadcast level 2.00
  storm-control multicast level 2.00
  vpc 1
interface port-channel2
  description vpc-peer-link
  switchport trunk allowed vlan 1,14,236
  speed 10000
  vpc peer-link
ip route 0.0.0.0/0 10.232.10.200
And the routing table:
sh ip route vrf all
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
0.0.0.0/0, ubest/mbest: 1/0, pending
    *via 10.232.10.200, Vlan14, [1/0], 00:00:55, static
10.232.10.0/24, ubest/mbest: 1/0, attached, pending
    *via 10.232.10.62, Vlan14, [0/0], 00:00:55, direct
10.232.10.62/32, ubest/mbest: 1/0, attached, pending
    *via 10.232.10.62, Vlan14, [0/0], 00:00:55, local
10.233.40.12/30, ubest/mbest: 1/0, attached, pending
    *via 10.233.40.13, Vlan26, [0/0], 00:00:55, direct
10.233.40.13/32, ubest/mbest: 1/0, attached, pending
    *via 10.233.40.13, Vlan26, [0/0], 00:00:55, local
IP Route Table for VRF "management"
svibeesh85
Mate check the ip addressing for te mgmt vlan.  Along with the mask.  Unable to ping within the mgmt vlan needs to be checked out. Chek if the uplink is allowin the mgmt vlan
Steve Fuller
Level 9
Level 9
It's late, but do your VLANs match?
It seems you have VLAN 14 and 26, but your port-channel is configured for VLANs 14 and 236. Is that a fat finger adding a 3 or a tied eye reading it incorrectly?
Sent from Cisco Technical Support Android App
Yes, thats correct. Vlan 14 is management ip address and vlan 26 is for the keepalive link.
in the meantime i reconfigured the switches the recommended way (keepalive over mgmt0) and the problem persists. after a reboot, everything works as expected...
now i will reconfigure the switches with my prefered config again. let's see what will happen....
My point is that you do not allow VLAN 26 on the port-channel. The only VLANs allowed are 14 and 236 (two hundred and thirty six).
Ah ok. i forgot to tell you this part of my config:
interface Ethernet1/1
  description vPC Keepalive
  switchport access vlan 26
  speed 1000
Do not allow the keepalive vlan on the VPC Link. this will break the communication and when the vpc link went down, you will have a split brain scenario! To avoid this, you can configure an extra vrf for the keepalive. see my final config.
My final config now is a separate VRF for the keepalive. this makes some things easer.
vrf context VPC-KEEPALIVE
peer-keepalive destination 10.233.40.14 source 10.233.40.13 vrf VPC-KEEPALIVE precedence 7
interface Vlan14
  no shutdown
  management
interface Vlan26
  no shutdown
  vrf member VPC-KEEPALIVE
What we have now is: Keepalive over fiber (e1/1 nexus 5k-1 to e1/1 nexus 5k-2) and an inband management over a trunked vlan.
