01-29-2015 08:09 AM - edited 03-07-2019 10:26 PM
I am trying to ISSU upgrade our Nexus 7K 10 slot switch from 5.2.7 to 6.2.8a The ISSU has failed multiple times due to the Standby Supervisor failing to come back online with the message
Install has failed. Return code 0x4093001e (Standby failed to come online)
Please identify the cause of the failure, and try 'install all' again.
Start type: SRV_OPTION_RESTART_STATELESS (23)
Death reason: SYSMGR_DEATH_REASON_NEED_COPYRS (19)
Last heartbeat 0.00 secs ago
System image name: n7000-s1-dk9.6.2.8a.bin
System image version: 6.2(8a) S2
Exit code: SYSMGR_EXITCODE_NEED_COPYRS (66)
Has anyone else experienced this before and found a solution?, any suggestions are welcome at this stage. I've followed the ISSU guidelines to the core. Please help!!
thanks, Sujohn
01-29-2015 09:23 AM
Are you following these guide lines before attempting to upgrade?
efore attempting to use ISSU to upgrade to any software image version, follow these guidelines:
Link:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/upgrade/guide/b_Cisco_Nexus_7000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_6-x.html#con_317522
01-30-2015 03:53 AM
Hi Reza,
I've followed all the instructions properly and even had other collegues review my prep work. Any ideas will help at this stage
thanks, Sujohn
01-31-2015 03:12 AM
Just out of interest are you using F Cards with M cards? Reason I ask is because i want to give you a warning if that is the case. Performing ISSU to 6.2.8a will cause the proxy routing used by F card via the M cards to fail or mis-function on certain flows (Completely Random) dependant on the FIB entries being mis-programmed in to the wrong SPL banks. See Bug ID CSCup96876
Better off doing a traditional upgrade of reloading to this version if you can.
How many SUPs do you have in the N7K? The below table shows that you can go from 5.2.7 to 6.2.8a in ISSU but cannot do ISSD in case.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/release/notes/62_nx-os_release_note.html#84013
hth
Bilal
05-20-2016 07:05 AM
I know this is an old thread but I had a similar problem with error message "error code
SYSMGR_EXITCODE_NEED_COPYRS (66)" when attempting to upgrade from 6.1x to 6.2x and it was related to memory requirements. I had 4GB and needed 8GB of RAM to support 6.2. People who run into should check your RAM requirements on the release notes.
