Nexus OSPF passive interface
satish.txt1
Level 5
Level 5
I have Cisco Nexus 9396PX switch and running OSPF configuration and now i want to tell all switch interface to not participate in ospf adjacency except only specific interface, so i there any global command to tell all interface in passive.
Here is my config, only eth2/11 and eth2/12 are participating in ospf routing but i want to make sure it does not send OSPF update to all  48x10GE  (all other 10G ports) in that case do i need to do  "ip ospf passive-interface"  on all interface?
N9K# sh run ospf
!Command: show running-config ospf
!Time: Thu Apr 26 15:22:04 2018
version 7.0(3)I4(7)
feature ospf
router ospf 100
  router-id 192.168.255.19
  default-information originate
interface Ethernet2/11
  ip router ospf 100 area 0.0.0.0
interface Ethernet2/12
6 Replies 6
Reza Sharifi
No, you just need it for e2/11 and e2/12.
I didn't get it, You are saying i should set `passive-interface default` in ospf config and tell e2/11 & e2/12 to "no ip ospf passive-interface" ?
In current config for testing i did "debug ip ospf hello" and found its just sending "hello" on e2/11 & e2/12 so look like i don't need do any passive-interface config, am i right?
The easiest way to do this is by adding
to both e2/11 & e2/12
So, neither interface with form adjacency.
You can also do it the other way too by adding
passive-interface default to OSPF and then add
"no ip ospf passive-interface" to each interface
but I like the first option.
Why do you think first option is best?
"ip ospf passive-interface both e2/11 & e2/12" This command stop OSFP on both interface, in my case i want both interface run OSFP process on e2/11 & e2/12 and stop OSPF on all other interface.
I think second method would be best default OSFP default and do "no ip ospf passive-interface" on e2/11 & e2/12
router ospf 100
int e2/11
int e2/12
easiest solution..
fangyachi
Community Member
ospf instance's command "passive-interface default" will override your configuration of interface
