Nexus Peer switch command
adamgibs7
Level 7
Level 7
Dears,
as it is mentioned in the below link  that while entering the peer switch command it behaves like one switch by which command i can see the same bridge ID ???? as if now when i can see the show spanning-tree vlan X it shows me core2 as a root and core 1 as a primary, how i can justify to the client how the command is in effect.
This requirement comes from the origin of vPC peer-switch: both peer devices present themselved as a unique STP root device using the same bridge ID.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
Hi ,
Have a look on the below link for better clarification...
http://www.cisco.com/c/en/us/support/docs/routers/7000-series-routers/116140-config-nexus-peer-00.html
Hope it Helps..
-GI
Ganesh Hariharan
Dears,as it is mentioned in the below link  that while entering the peer switch command it behaves like one switch by which command i can see the same bridge ID ???? as if now when i can see the show spanning-tree vlan X it shows me core2 as a root and core 1 as a primary, how i can justify to the client how the command is in effect
When you enable peer-switch command in Nexus, each single node nexus will share a virtual bridge ID  which allows both of them to act as root for the vlan.  For devices  with a connection to each N7k in the vPC domain that are not capable of  port-channel, L2 topology will rely on STP to block the redundant  links.
The peer-switch feature allows for pseudo STP configurations to  allow non-vPC connections to load balance between the two N7k's.
The vPC peer-link will  always be in a forwarding status and it runs Layer 2 Gateway  Interconnection Protocol (L2GIP) to prevent bridging loops.  Each nexus  switch will send BPDUs with root bridge identified by virtual  bridge-ID.
On vPC links, the designated bridge ID will also have the  virtual bridge-ID.  For non-vPC links, the designated bridge ID will be  the physical bridge-ID of the corresponding Nexus switch.
This allows  for the non-vPC switch (SW-1) to make a root decision based on the BPDU  advertisements instead of depending on port-priority to break the tie.
Hope it Helps..
-GI
Dear
how ??
how i can see the virtual bridge id
Hi ,
Hope it Helps..
-GI
thanks ganesh
very good doc
