03-26-2021 09:58 AM
Hello everyone,
I have a situation here with a nexus switch, once im applying the qos on interface its gives me the following error and link goes into error disable :
Nexus-165(config)# int e101/1/11 Nexus-165(config-if)# service-policy type qos input pm-ingress ERROR: Unable to perform the action due to incompatibility: Module 1 returned status "label allocation failure" Nexus-165(config-if)# shut Nexus-165(config-if)# service-policy type qos input pm-ingress Nexus-165(config-if)# no shut Nexus-165(config-if)# end
2021 Mar 25 17:43:25.232 UTC Nexus-165 %ETHPORT-5-IF_SEQ_ERROR: Error ("label allocation failure") communicating with MTS_SAP_IPQOS_MGR for opcode MTS_OPC_ETHPM_PORT_BRINGUP (RID_PORT: Ethernet101/1/11) 2021 Mar 25 17:43:27.257 UTC Nexus-165 %ETHPORT-5-IF_DOWN_ERROR_DISABLED: Interface Ethernet101/1/11 is down (Error disabled. Reason:label allocation failure)
once no service-policy type qos input pm-ingress
Any one have an idea regarding this issue ?
03-26-2021 02:36 PM
int e101/1/11
is thsi FEX port ?
can you post below output :
Show version
Show tech ipqos
Show run ipqos
show run int e101/1/11
08-29-2022 04:52 AM
Hi there,
I have exact the same issue. Is there any update on this?
BR Konrad
08-29-2022 09:29 AM
if the issue same, you need to post the required information to assist better.
