02-15-2024 07:30 AM
Does this config make sense?
interface port-channel10
switchport
switchport mode trunk
no lacp suspend-individual
spanning-tree port type network
no snmp trap link-status
vpc peer-link
It's the same on a vpc pair, primary and secondary and NOT showing the command vpc 10
It's a production system I inherited, and it's working so I'm guessing it's not a necessary command?
Or it is necessary and explains some issues.....?
By the way, great post: Nexus - vPC Recommendations - Cisco Community
Solved! Go to Solution.
02-15-2024 07:42 AM
Nexus
NSK1-po10-NSK2
In po1 you need to use vpc peer-link
This po carry data and mgmt traffic between two NSK
NSK1-PO100-SW
NSK2-PO100-SW
Here in PO100 you need vpc 100(or any other number you want)
So only the PO interconnect two NSK need vpc peer-link ' other use vpc
MHM
02-15-2024 07:42 AM
Nexus
NSK1-po10-NSK2
NSK1-PO100-SW
NSK2-PO100-SW
MHM
02-15-2024 07:53 AM
Much appreciated...
