Nexus, vPC, FEX, VRRP, ICMP Redirects
wilson_1234_2
Level 3
Level 3
I have two nexus 5K switches in a vPC config. A FEX is uplinked to the two N5Ks vis Port-Channel 1, vPC1.
We have VRRP configured on a particular VLAN that is isolated via VRF. Nexus 1 is the primary (10.6.5.5), Nexus 2 is the backup (10.6.5.6
I am trying to understand why I am seeing ICMP redirects, and I think it may have to do with the fact that the Nexus will randomly select which vPC member link will pass traffic to the core. But am not sure.
We have a host 10.6.5.100, that is configured with the VRRP virtual interface as it's default GW (10.6.5.2). The host is attempting to leave the network. I am seeing ICMP redirects that Nexus 2 (10.6.5.6) is telling host 10.6.5.100 to use Nexus 1 (10.6.5.5).
The question is, why is the host using Nexus 2?
Is it due to the random selection of vPC member port?
Is there a way to prevent the redirects?
Nexus1 Config
version 7.0(8)N1(1)
feature vpc
vpc domain 31
  peer-keepalive destination 10.8.5.2 source 10.8.5.1
  delay restore 150
interface port-channel1
  description FEX 1
  switchport mode fex-fabric
  fex associate 101
  vpc 1
interface Vlan11
  no shutdown
  vrf member HQ
  ip address 10.6.5.5/24
  ip router ospf 11 area 0.0.0.0
  vrrp 199
    address 10.6.5.2
    no shutdown
Nexus2 Config
version 7.0(8)N1(1)
feature vpc
vpc domain 31
  peer-keepalive destination 10.8.5.1 source 10.8.5.2
  delay restore 150
  description CABINET#2//FEX 1
  fex associate 101
  vpc 1
interface Vlan11
  no shutdown
  vrf member HQ
  ip address 10.6.5.6/24
  vrrp 199
    priority 95
    address 10.6.5.2
    no shutdown
Reza Sharifi
Can you add "peer-gateway" command to vpc domain 31 on both 5ks and test again?
I thought about the peer-gateway command, but didn't know if it would be disruptive
I am not sure if it is distributive.  So, I would test it in non-production hours or during a maintenance window.
