Nexus vPC inconsistencies due to different lag-id
Dirk Feldhaus
I have a scenario where 2 Nexus9k are acting as vPC pair and a NetApp appliance is connected to both switches. The port on 1 switch is disabled due to vPC inconsistencies. The only difference I can spot is the number 32 and 52, respectively, in the lag-id.
switch-1# show vpc consistency-parameters interface port-channel 17
Legend:
Type 1 : vPC will be suspended in case of mismatch
Name Type Local Value Peer Value
lag-id 1 [(7f9b,                        [(7f9b,
0-23-4-ee-be-66, 82b3,                    0-23-4-ee-be-66, 82b3,
0, 0), (8000,                             0, 0), (8000,
2-a0-98-aa-fa-cf, 32,                     2-a0-98-aa-fa-cf, 52,
0, 0)]                                    0, 0)]
mode 1 active                             active
Speed 1 10 Gb/s                           10 Gb/s
Duplex 1 full                             full
Port Mode 1 trunk                         trunk
Native Vlan 1 0                          0
MTU 1 9000                                9000
vPC card type 1 Empty                     Empty
Allowed VLANs - 3967                      3967
Local suspended VLANs - -                 -
switch-1#
Does anyone know what these numbers (32 and 52) mean why they might be different?
Reza Sharifi
That is part of the Lag id and it should be the same on both sides.
Can you post the config for Po17?
Also, what is the output of "sh port-cha summ"?
This is on Cisco ACI, so there is no traditional config for the port-channel.
In the meantime we bounced the vPC and it came back up correctly.
Now it is "52" on both sides. Do you have an idea where this number 52 and 32, respectively, are coming from. At the moment I'm not even sure if it is generated on the switch or the NetApp.
switch-1# show port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
S - Switched R - Routed
U - Up (port-channel)
M - Not in use. Min-links not met
F - Configuration failed
Group Port- Type Protocol Member Ports
Channel
17 Po17(SU) Eth LACP Eth1/5(P)
