Nexus vPC to Arista MLAG
tporembski
Can you connect an Arista switch using their MLAG technology to a nexus 5K or 2K using vPC?
2 Accepted Solutions
Cisco vPC to Arista MLAG works fine in my experience. I've used Cisco vPC to Arista MLAG using only two links as you're proposing, and also four links e.g., Nexus 1 to Arista 1 and 2, Nexus 2 to Arista 1 and 2.
Here's a sample configuration for the two link option. I have port-channel 1 as the peer link (for both Cisco and Arista) and port-channel 200 as the link between the Cisco and Arista:
! Arista 1
vlan 4094
   trunk group MLAG_Peer
interface Vlan4094
   ip address 172.17.255.1/30
mlag configuration
   domain-id MLAG1
   local-interface Vlan4094
   peer-address 172.17.255.2
   peer-link Port-Channel1
interface Port-Channel1
   switchport mode trunk
   switchport trunk group MLAG_Peer
interface Ethernet47
   channel-group 1 mode active
interface Ethernet48
interface Port-Channel200
   mlag 200
interface Ethernet10
  channel-group 200 mode active
! Arista 2
vlan 4094
interface Vlan4094
   ip address 172.17.255.2/30
mlag configuration
   domain-id MLAG1
   peer-address 172.17.255.1
   mlag 200
# Nexus 5K1
interface mgmt0
  vrf member management
  ip address 192.168.1.7/25
feature vpc
vpc domain 11
  peer-switch
  role priority 1
  peer-keepalive destination 192.168.1.8
  delay restore 60
  peer-gateway
interface port-channel1
  spanning-tree port type network
  vpc peer-link
interface Ethernet2/1
interface Ethernet2/2
interface port-channel200
  vpc 200
interface Ethernet1/27
# Nexus 5K2
interface mgmt0
  ip address 192.168.1.8/25
feature vpc
vpc domain 11
  peer-switch
  role priority 1
  peer-keepalive destination 192.168.1.7
  delay restore 60
  peer-gateway
  vpc peer-link
  vpc 200
And here's a couple of show commands on the Arista for good measure:
a7150s-1#sh mlag
MLAG Configuration:
domain-id           :               MLAG1
local-interface     :            Vlan4094
peer-address        :        172.17.255.2
peer-link           :       Port-Channel1
MLAG Status:
state               :              Active
negotiation status  :           Connected
peer-link status    :                  Up
local-int status    :                  Up
system-id           :   02:1c:73:42:6d:31
MLAG Ports:
Disabled            :                   0
Configured          :                   0
Inactive            :                   0
Active-partial      :                   0
Active-full         :                   1
a7150s-1#sh mlag interfaces
        local/remote
   mlag       desc             state       local       remote          status
    200                  active-full       Po200        Po200           up/up
a7150s-1#sh mlag interfaces detail
                                                          local/remote
  mlag            state       local       remote        oper        config               last change    changes
   200      active-full       Po200        Po200       up/up       ena/ena       1 day, 22:30:04 ago         14
a7150s-1#show port-channel 200 traffic
ChanId      Port Rx-Ucst Tx-Ucst Rx-Mcst Tx-Mcst Rx-Bcst Tx-Bcst
   200      Et10  42.27%   0.00%  46.62%  16.29%   0.00% 100.00%
a7150s-2#show port-channel 200 traffic
   200      Et10  29.51%  81.42%  53.13%   6.64% 100.00% 100.00%
I've connected switches off Nexus 2K host interfaces, but not Nexus 2232. I've only done this as a last resort to connect legacy blade switches at 1GE to Nexus 2248T.
As you're probably aware, the FEX operates with Spanning Tree BPDU Guard on the host interfaces, and unless it's changed in recent releases, this cannot be disabled.
What that means is that to connect a switch to a FEX you need to enable Spanning Tree BPDU filter (spanning-tree bpdufilter enable). This essentially disables Spanning Tree on the interface and can obviously be a little dangerous as any loop that was introduced would never be blocked.
If you're absolutely certain there can be no loops introduced this is an option, but I'd consider it only when there are no other options.
Personally I'd rather try and use ports on the Nexus 5K directly and run in a supported and standard approach than connect the Arista to a FEX and have to disable spanning tree.
7 Replies 7
Reza Sharifi
So, your design is one Arista switch and 2 Cisco Nexus 5ks or 2 Arista switches?
The design is 2 Arista switches and 2 Cisco Nexus 5K.  Each Arista has one connection to each Nexus switch.
! Arista 1
vlan 4094
interface Vlan4094
mlag configuration
   domain-id MLAG1
   mlag 200
! Arista 2
vlan 4094
interface Vlan4094
mlag configuration
   domain-id MLAG1
   mlag 200
# Nexus 5K1
interface mgmt0
feature vpc
vpc domain 11
  peer-switch
  role priority 1
  delay restore 60
  peer-gateway
  vpc peer-link
  vpc 200
# Nexus 5K2
interface mgmt0
feature vpc
vpc domain 11
  peer-switch
  role priority 1
  delay restore 60
  peer-gateway
  vpc peer-link
  vpc 200
a7150s-1#sh mlag
MLAG Configuration:
domain-id           :               MLAG1
MLAG Status:
state               :              Active
MLAG Ports:
Disabled            :                   0
Configured          :                   0
Inactive            :                   0
Active-partial      :                   0
Active-full         :                   1
        local/remote
                                                          local/remote
Just discovered the Arista switches are connecting to Nexus 2232(FEX)  off a N5K.  I know the 2232 is not designed for switch connectivity.  Do you have any experience connecting to 2232.  I have connectivity but the vlans on the trunk are not forwarding.
Thanks.  I knew about that and we found out that it does cause issues so we will be running to N5K.
tporembski
Thanks.  that's the confirmation I needed.
