nexus2k etherchannel
SHAIHAN JAFFREY
There are two IBM servers that will be connected to Nexus 2k switch.
Two Ethernets from each server will be terminated on the Nexus2k.I
In all 4 ports will be part of a single ether channel which will communicating through LACP
Please let me if this is possible and what will be the configuration steps.
SHAIHAN JAFFREY
The Nexus 2K is 2148T. Can anyone help me on this?
It should work just fine.  Remember the 2k does not work by itself, you also need to have a set of 5Ks or 7Ks to uplink the 2ks to.
Oleksandr Nesterov
Hello Jaffrey
You also need to configure both your servers to send same LAG ID for LACP link - to let N2k box now that all these links are part of the same port-channel.
HTH,
Alex
