Nexus7000 C7010 (10 Slot) Chassis with N7K-SUP1, VPC and jumbo frames
darin.marais
Level 4
Level 4
Is there anyone on this forum that would be able to help me answer to this question!
Is jumbo frames MTU 9216 supported across a VPC between 2 x Nexus7000 C7010 (10 Slot) Chassis with Supervisor module-1X" PID: N7K-SUP1 , VID: V15 and  BIOS: version 3.22.0 / kickstart: version 6.0(3) / system: version 6.0(3) / BIOS compile time: 02/20/10
Yes I am well aware that the product is end of life / end of support!
Thanks in advance!
Steven268Danner
Jumbo frames with an MTU of 9216 are typically supported on Nexus 7000 series switches. However, since the product is end of life/support, it’s best to refer to the original documentation or community forums for confirmation, as official support may no longer be available for queries on legacy systems.
Helpful but is MTU 9216 possible across a VPC between 2 x Nexus7000 C7010 (10 Slot) Chassis with Supervisor module-1X" PID: N7K-SUP1 , VID: V15 and system: version 6.0(3)
Config mtu 9216 and then ping between any two svi using this mtu and df bit set and see if packet will pass or not.
MHM
