Nexus7k switch error logs
haiyang xu
Community Member
                Hi all,
We are getting some error logs on Nexus VDC,as follows:
2012 Nov 23 08:49:11 N7K_B-Network_Center_B %$ VDC-3 %$ last message repeated 6 times
2012 Nov 23 08:50:21 N7K_B-Network_Center_B %$ VDC-3 %$ last message repeated 7 times 2012 Nov 23 08:49:11 N7K_B-Network_Center_B %$ VDC-3 %$ last message repeated 6 times
     I couldn't find the solution in cisco.com,Plz help.
Sebju Varghese
Hi Haiyang,
There are lots of message repeating and its programmed to show these repeated message counts to reduce overwhelming.
Could you please share following outputs.
1) show logging last 100 - Need to check which messages are repeated.
2) Logging level configurations on your box.
Sebju
