connection problem
kamel
Community Member
Hi guys,
I have 3 sites with the same ip range 10.1.1.0 etch site only have layer 2 switch.
Now I need to add backup server to be centralize between the sites. The problem that I can't change the ip addresses in any site because it's a production network.
Any one have idea for this problem.
Thanks and best regards
Kamel
Hi Kamel,
Do Nating if you have additional resources like Router or firewall at central location. Please follow the link.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f8e.shtml.
Please rate helpful posts
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
kamel
Community Member
Thanks a lot I try it and it's works
Hi Kamel
You are welcome.
Please rate helpful posts. It may help others. If you have no other queries, please mark this answered.
Tanveer
Sent from mobile
Hi kamel,
can you plz tell us.....
what does mean of  "i can't change ip of any site".
why do you need this ?
which type of backup server do you want to centralize ?
