Nexus9000 93180YC-EX Switch port link flapping
drkershner
 Current ethernet port has been in operation for months. Now it's flapping and erroring out
 %ETHPORT-5-SPEED: Interface Ethernet104/1/10, operational speed changed to 1 Gbps
 %ETHPORT-5-IF_DUPLEX: Interface Ethernet104/1/10, operational duplex mode changed to Full
 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet104/1/10, operational Receive Flow Control state changed to off
%ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet104/1/10, operational Transmit Flow Control state changed to on
 %ETHPORT-5-IF_UP: Interface Ethernet104/1/10 is up in mode access
 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet104/1/10 is down (Link failure)
 After a lot of the above the port errors out and shuts down. Looking at the port I don't see any errors
RX
    30975995 unicast packets  26 multicast packets  761 broadcast packets
    30976782 input packets  7256309962 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    30461084 unicast packets  7112931 multicast packets  38163234 broadcast packets
    75737249 output packets  7921727958 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
Any ideas? There were  no config changes on the switch side
interface Ethernet104/1/10
description XXXXXXXXXXXX
switchport access vlan XX
no shutdown
Try hardcoded duplex in both sides
Also try use FEC in both sides
MHM
