NIC Teaming/Bonding
chandra_rc16
Level 4
Level 4
Do anyone has a doc or link for NIC teaming/bonding ?
Thanks in advance.
Chandu
Regards, Chandu
Sandeep Choudhary
Hi Chandu,
NIC teaming is the process of grouping together several physical NICs into one single logical NIC, it can be used for network fault tolerance and transmit load balance. The process of grouping NICs is called teaming.
It has two purposes:
Fault Tolerance: By teaming more than one physical NIC to a logical NIC, high availability is maximized. Even if one NIC fails, the network connection does not cease and continues to operate on other NICs.
Load Balancing: Balancing the network traffic load on a server can enhance the functionality of the server and the network.
example: http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a008089a821.shtml
Hope it helps.
Dont forget to rate helpful posts.
Thanks for the help Sundeep.
Can you elobarate it in the Datacentre point of view ? I mean how it is used on servers in DC.
Chandu
Regards, Chandu
