NM-1FE-FX and 3745
RoboCisco
All,
Wondering if anyone knows if the NM-1FE-FX will work in a 3745 router. I've looked up the NM-1FE-FX on the Cisco Solution Finder, but the 3745 doesn't even show up on the list. I assume that the 3745 is not listed because it has been discontinued. Anyone know? Says this module does work in the 3725.
Appreciate the assistance.
Edison Ortiz
Yes, it's supported.
__
Edison.
Edison Ortiz
__
Edison.
Outstanding, thanks...
