NM HDV2 1T1/E1 - Layer 1 is Active and Layer 2 - TEI _ASSIGNED
astanislaus
Level 2
Level 2
The carrier terminated the line on a Chrone Block and gave me the pin-outs on that punch-down block.
So I made up a cable and connected that cable from that Chrone Block to the Rj45.
With the following outputs, can I assume my cable pin-outs and connections are fine, because otherwise even layer 1 won't become ACTIVE. Or could I still have a cabling issue with TX+, TX-, TX= and Rx-?
sho controller e1
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20040802, FPGA: 255, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Current port master clock:recovered from backplane
Data in current interval (436 seconds elapsed):
8349 Line Code Violations, 6 Path Code Violations
20 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
19 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 65 Unavail Secs
snovoicertr02#sho isdn sta
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 10
Total Allocated ISDN CCBs = 0
snovoicertr02#sho int s1/0:15
Serial1/0:15 is up, line protocol is up (spoofing)
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:07:28
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
2 carrier transitions
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
sourabhagarwal
Level 4
Level 4
"show isdn status" output says that Layer 1 is ACTIVE, so i feel there is no issue at physical layer.
However, Layer 2 of interface Serial1/0:15 is not in 'MULTIPLE_FRAME_ESTABLISHED'
state.
Make sure that your service provider's switch type is primary-net5. If not, modify your switch type accordingly.
The interface-specific ISDN switch setting will override the global switch setting.
Also Verify the T1/E1 is configured to match the provider's switch. To see the layer 2 negotiations between the switch and the router, use the privileged exec command 'debug isdn q921'
HTH, rate if it does ....
