no auto-negotiation on only one device on either switch?
SW#sh run int g1/0/1
interface GigabitEthernet1/0/1
 switchport mode trunk
 channel-group 1 mode on
SW#sh run int g1/0/2
interface GigabitEthernet1/0/2
WLC#sh run int t0/1/0
interface TenGigabitEthernet0/1/0
 speed 1000
 no negotiation auto
WLC#sh run int t0/1/1
interface TenGigabitEthernet0/1/1
 speed 1000
 no negotiation auto
The WLC is hardcoded to speed 1000 and does not negotiate.
The switch to which the WLC is connected is auto-negotiating.
The problem is that sometimes the EtherChannel goes down.
I suspect this is due to the hardcoding of the WLC interface.
What do you all think?
7 Replies 7
cisco recommend that both side must match
so if your WLC is no autonego then SW interface must also no autonego
MHM
I know that too. Can you provide documentation??
since the current link is normal, I need to prove the problem in order to change the config.
The problem is that sometimes the EtherChannel goes down. <<- this stop me and I think that the speed not issue here
if the Speed or duplex is mismatch then it not work at all, here as you mention it SOMETIMES goes down
what making the PO go down ??
so let review the config, why you use mode ON ? the WLC support LACP and it protect SW and PO from L2 Loop
MHM
I didn't set it up. But I'm planning to change to active mode tonight.
you comment in other post,
and you share show of port member not the PO,
can you share the show of interface PO
also you can use show interface status
MHM
can you update me
MHM
Joseph W. Doherty
Speed is usually not a negotiating issue, as other side can "clock" bit rate.
Duplex, though, is very much impacted by negotiating setting.
If you have a duplex mismatch, interfaces will pass traffic, by at a very slow rate due to transmission/reception errors.  If you're getting enough of these errors, possibly interface takes itself down as part of a reset.
Either switch or WLC show any log message when EtherChannel goes down?  Errors on interface stats?
