Auto QoS: 9200 and 9400 switchse
jaheshkhan
Level 5
Level 5
client have 3 IDF that are connected to core switch? IDFs are 9200 switches. core switch is 9400 .
May I know how to apply Auto Qos commands here? how about it should apply on uplink ports?
what I remember its just one command .
if anybody familiar may I know the template to apply there on access and link aggregation trunk uplink ports on IDF and core switch
balaji.bandi
yes correct check below configuration guide :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/16-9/command_reference/b_169_9200_cr/b_169_9200_cr_chapter_01010.html
Also consider using this command - qos queue-softmax-multipler 1200
If you looking to deploy end to end need to apply where it required depends on the requirement.
BB
