No Client DHCP Using ASA 5505 and AIR-AP1041N-A-K9
waynemdwt1
I have setup hundreds of different routers, switches, and access points from multiple vendors over the years, but have virtually no Cisco experience so please forgive my ignorance.
I need to configure public and private wireless access using an ASA 5505 and an Aironet  AIR-AP1041N-A-K9. I need to be able to do this via ASDM and http if at all possible. I simply do not have the time to learn hundreds of lines of arcane CLI code.
The Aironet connects to the ASA successfully, and receives an IP. I can then connect to the AP wirelessly, but do not receive an IP. I have setup a second SSID\VLAN on the AP, and can't connect to it at all.
Please point me in the right direction. Thanks!
waynemdwt1
Bump
siddhartham
Level 4
Level 4
ASA drops the unicast DHCP requests. So if the AP is acting as a Proxy for the client DHCP requests, it won't work. Can you post your config of the access point.
Siddhartha
Siddhartha
version 12.4
no service pad
service password-encryption
hostname CB
logging rate-limit console 9
enable secret 5 $1$82pL$3KLewL/tBDJqMKMqKFm98/
no aaa new-model
dot11 syslog
dot11 ssid CBCustomer
   vlan 2
   authentication open
   guest-mode
dot11 ssid CBSecure
   vlan 1
   authentication open
username Cisco password 7 072C285F4D06
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 key 1 size 128bit 7 DC09DE3C9349E57CDB2E2B52782F transmit-key
encryption vlan 1 mode wep mandatory
ssid CBCustomer
ssid CBSecure
antenna gain 0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Please add the below command under interface BVI1 and see if that fixes your issue
ip helper-address X.X.X.X (address of your DHCP server)
interface BVI1
Siddhartha
