06-06-2019 04:00 AM
Hello together :)
So I will try to explain my problem with my bad English and hope that somebody can help me with that.
I just bought a Meraki MX250 for our company to replace an older Firewall and I confugured it exactly like the old Firewall just with another public IP. So far so good.
But when I try to connect the Meraki MX250 over the WAN port to the Cisco 3560 switch, nothing happens. I don't get any link and the port on the 3560 says that nothing is connected.
I have resetted the port already, also the Firewall. But still nothing.
When I connect the Firewall to another office Switch, it is working without any issues.
The port on the 3560 is also not broken or something because when I connect something else on it, I got a link too.
So both connections are working with different devices. I can't just get it why I don't get any link when I connect the firewall to the 3560 switch.
And yes, I need this switch, because it is the switch between our internet and the company network.
So far
Daniel
Solved! Go to Solution.
06-07-2019 06:36 AM
Hello
media type is 10/100BaseTX
I on the understanding the Mx's use by default 1GB interconnects for its wan/internet ports so it is possible it cannot negotiate with the 3560 at 100mb.
06-06-2019 04:09 AM
Can you post the configuration of the port you connecting MX250
06-06-2019 05:49 AM
06-07-2019 05:46 AM
Oh yes, sorry forgot it:
So I tried it on these 3 ports, without any result:
FastEthernet0/1 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 0024.98db.a483 (bia 0024.98db.a483)
Description: Meraki_MX250_WAN01
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 2d01h, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 packets input, 620 bytes, 0 no buffer
Received 4 broadcasts (4 multicasts)
0 watchdog, 4 multicast, 0 pause input
37 packets output, 5860 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
____________________________________________________________
FastEthernet0/3 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 0024.98db.a485 (bia 0024.98db.a485)
Description: Meraki_MX250_WAN02
Full-duplex, 100Mb/s, media type is 10/100BaseTX
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
_____________________________________________________________
FastEthernet0/5 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 0024.98db.a487 (bia 0024.98db.a487)
Last input never, output 2d02h, output hang never
1 packets output, 452 bytes, 0 underruns
Hope this helps.
Thanks!
06-07-2019 06:36 AM
Hello
06-11-2019 01:46 AM
