no connection to lan port
aconticisco
Level 2
Level 2
Hello all,
I have a 1721 router installed with both an adsl wic and a 4 port switch wic card. My setup is as follows:
pc connected to port 3 (mode access on vlan 20) on the 4 port switch wic  (installed in 1721 router)
port 4 is configured as trunk (encap dot1q) and connected to fasethernet 0 (inbuild of 1721)
fastethernet 0 configured with no ip address
created sub-interface fastethernet 0.20 with encapsulation dot1q on vlan 20
ip address of sub interface 0.20 is 192.168.20.240
pc nic ip address is 192.168.20.245 however cannot ping 20.240 any ideas ?
I want to use only this router with its switch wic for vlans and internet
20 Replies 20
Hi Fabio,
Yes I like creative users
great troubleshooting session from you.
Regards.
Alain
You too Alan... it was simple this time i have seen your troubleshooting in other posts, and you are great.
Hi Fabio,
thanks but I'm far away from some other users here which are really experts.
Regards.
Alain
Thanks Again, Happy Christmas !
remember to close the post as resolved, for other user who can be your same problem--- happy xmass again.
what have you done previously was strange... the switch port was on the same router and the mac address was seen on a switched port and on a fa0/0 port... it and also the switch was seen in transit from a trunk port... Maybe the router see that mac address on it's cam table and doesn't respond to the same mac from a fa 0. The configuration was wrong conceptually, and other test will be necessary to give a proper response to your question, but i think what i previously written can be a possible cause.
